Results 1 to 7 of 7
Thread: geasing the pinions
    Jul 2011
    Timmins, Ontario, Canada
    Default geasing the pinions
    How often are we supposed to apply the supplied grease to the Buddy's rack and pinion system?
    Every so many hours? Or when it looks dry? Is there a set maintenence schedule?
    (guess I better have another look at the book)
    AJC
    You probably won't find much info 'in the book' on maintenance. I tell customers to keep the racks wet with grease, as steel on steel is not good. Also, grab some stainless el cheapo brushes from Horrible Freight and rake those teeth out when debris or hardened grease clogs the teeth.
    Alternatively you can use a good quality 'spray grease'. I like Cyclo brand with the green cap. Regular white lithium is not the correct lubricant. It is not thick enough to provide the 'cushion' that a true grease will provide. Of course, the spray grease is lighter than the grease that SB gives you & as a result, you should hit the racks about once every 40 hrs in my experience.
    To make life easy on yourself, set the MS to something like 1 IPS and spray the pinion with a 'blip' every second or two to evenly spread the grease. Then run the tool back and forth to distribute it & wipe the sides of the racks off with a rag.
    Mar 2005
    San Jose, CA, USA
    Talking
    I found the belly of my shirt was just as effective
    - Randall Newcomb
    10 fingers in, 10 fingers out
    another good day in the shop
    Jun 2007
    Hampton Roads, VA
    Quote Originally Posted by rcnewcomb View Post
    I thought the tooth pattern was part of the shopbot logo for the longest time ..
    May 2010
    Qualicum Beach, B.C.
    We always refer to that as a "Shopbot Smile", seeing as a bit of a paunch results in a happy looking grease stain.
    Can't tell you how many shirts I've ruined over the years ;-)
    Jul 2011
    Thanks Brady, will just use the tube they gave me until it runs out.
    Lucky for me I keep my shop and the buddy very clean, and I don't get any dust and grease mixing and making a paste. I have to say my dust collection is very good!
    Will grease once per week or two depending how much it gets used.
    When I was at the Aspire gathering I told Keith Outten about how I used a piece of vinyl to cover my racks and he said a piece of magnate roll would work also. I thought that was a good idea as you could just peel it off to grease and stick back on. I cut mine just a little wider than the rack so it doesn't interfere with the pinion.
  1. New Pinions, how snug should we be?
    By jTr in forum Assembly & Maintenance
    Last Post: 05-15-2015, 10:21 PM
  2. Loose pinions
    By Acmeaviator in forum ShopBotter Message Board
    Last Post: 01-02-2012, 09:20 AM
  3. Help with new pinions
    By frankwilliams in forum Archives2008
    Last Post: 05-05-2008, 09:44 PM
  4. Chatter and Pinions
    By drodda in forum Archives2007
    Last Post: 03-06-2007, 09:39 PM
  5. G4 UPGRADE AND NEW PINIONS
    By robert_cheal in forum Archives2007
    Last Post: 02-11-2007, 04:16 PM
