Wow... recommendations all over the place! And all from folks who are or have been cutting foam. My previous experience with foam would suggest that what works is what works for you (me in this case). I want Monty's down cut bit strategy to work even though it goes against all we teach about cutting plastics. I don't have vacuum and expect that tape will become difficult the nastier my work environment becomes. I hope that Monty's 1/2" bit recommendation allows chips to flow and not re-weld. Most are suggesting that higher flute counts work well... The most flutes I have on hand (I need to start cutting tonight) is three. A 1/4" 3 flute up cut and a 1/2" 3 flute down cut rougher / finisher. I'll be experimenting...Randy, thanks for the heads up on the 3M #74 glue
Steve
