For all those cabinet makers out there... I've been outsourcing doors for larger kitchen projects. I have one that is to be painted. I've only ever fabricated my own doors when painted.
In the past when I was making my doors in-house I would make the center panel (.5" veneer ply) the same size as the perimeter mortise. Then I would glue it in place and a 1/16" bead of caulk around the perimeter where the panel meets the frame. This leaves a seem less door. Or if it was a raised panel I would pre-finish it as to not see unpainted edges when the panel shrank.
My door fabricator floats the center panel, flat or raised. I am trying figure out what is the best way to prep out-sourced doors and finish them with paint without worrying about the center panel splitting the caulk seem from the frame.
Can I glue the panel in place and caulk as I usually do? How is this done properly? Materials will be soft maple and veneer covered MDF.
