Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: Shopbot Talks goes Green...
  1. #41
    Mar 2009
    Pope Valley CA
    Khalid,
    I don't have any experience with that particular design, but I like the simplicity and really only simple tools are needed to construct one.
    For low HP (like under 100), piston steam engines are actually more efficient than turbines, in my understanding.
    Also add to that the fact that a turbine will require relatively expensive gearing to get the output down to a reasonable rpm.
    The actual efficiency depends on a lot of factors; heat differential, condensing/recycling the steam, etc.
    Ron Sloan
  2. #42
    Nov 2008
    @Ron,
    The Green Engine is not that stable after watching the actuall video.. It has lot of vibration...so i am not thinking to make it...The steam turbine are high RPM but we have many options..we can use high RPM generators..we can regulate the steam to run them at low RPM...
    By the way..i am still in search of new ideas to work with...ma be we can invent some new innovative engine or solution...
    @Richard,
    Please do not order the plan.
    I left woodwork due to office work.
  3. #43
    montreal quebec
    http://www.free-energy-info.co.uk/u might find some help here.
    Good luck with the project!
  4. #44
    Nov 2008
    Default WindMill near completion
    Thank You Normand for informative website and greetings...
    I have made the Axial Flux generator and for mounting the 6feet long blades i have to make a plate.Did some more work on my windmill. Attached pictures shows blade mounting plate and some fixtures for blades holding on plate.
    I scanned the blade and then made the wooden fixture. In one of the picture you can see piece of blade fit on the wooden fixture.
  5. #45
    Nov 2008
    WindMill was assembled and with a minor wind got it rotation at No load. Still needs wiring and improvement in other things..especially balancing of blades...
  6. #46
    Nov 2008
    Default Dont warn me..
    My son standing near the windmill.. Windmill rotataing at 5000RPS
    Its rotating 10RPM or less but my camera shows like .........
    My son is at very safe distance i swear...so don't warn me...
  7. #47
    You should put a fence or something to keep someone from walking into the blades. I have seen pictures of small plane pilots that had a forgetful moment and that was their last one. I would hate to see that cute little guy hurt. kids have a habit of not paying attention when they are having fun.
  8. #48
    Mar 2009
    Pope Valley CA
    Looking good Khalid!
    Can't wait to see it finished and what the output is!
    Ron Sloan
  1. Green Ebony?
    By Burkhardt in forum ShopBotter Message Board
    Last Post: 05-08-2016, 10:30 PM
  2. Red or Green?
    By road_king in forum Folder 2011
    Last Post: 12-11-2011, 09:59 PM
  3. Cutting green luminous plactic
    By dubliner in forum ShopBotter Message Board
    Last Post: 03-08-2010, 11:23 PM
  4. Freehand 3D Carving in Green Applewood
    By rcnewcomb in forum Folder 2009
    Last Post: 10-23-2009, 07:30 PM
  5. Going Green???
    By Gary Campbell in forum Archives2007
    Last Post: 09-28-2007, 11:18 AM
