Results 1 to 7 of 7
Thread: Head2 Indexer Post
    Wild Atlantic Way
    Default Head2 Indexer Post
    Does anyone have a metric Indexer post for Head 2 they are willing to share.
    Many thanks
    Paul
    Garland Tx
    Paul
    Just to clarify what you want... " for head 2" do you mean that your indexer is on axis A rather that the normal "B" ... or do you mean that you have two indexers?
    Are you wrapping the X axis or the Y axis? usually indexers are in degrees and independent of metric/imperial designation...
    edit:
    I see that my PP says "inch" and I don't see any listed as metric. I obviously don't know something here!
    Wild Atlantic Way
    Hi Steve,
    My indexer is on a PRSAlpha running parallel to my Y axis wrapping the X axis. My main spindle is Z, my second spindle is A and my indexer is B.
    I got the Metric indexer post from Vectric.
    I would like to have two tools set up and combined in one file using the MasterMaker from Shopbot.
    Paul
    Garland Tx
    Paul
    I'm glad you got the PP you needed!
    I know it's off topic but since you brought it up... What do you mean by "two tools". Do you mean two ShopBots or are you talking about using your two Z's as a defacto tool changer? Also is there a newer version of "MasterMaker" than the 2007 version that doesn't recognize HDD's other than C:\ ?
    garyc Guest
    Paul...
    It sounds like you are looking for a metric version of the MTC post with indiexer output. I am not sure that one exists, but will check on it tomorrow.
    Wild Atlantic Way
    Steve,
    That's correct, I want to use two Z's as a defacto tool changer.
    Gary,
    I think that is exactly what I need, I hope you have one !!!!
    Many thanks
    Paul
    garyc Guest
    Paul...
    We have one here that you can test. It has been used here, but with an ATC and an indexer. Send me an email to gary.campbell (at) shopbottools.com and I will send it back
  1. Indexer Post Processor
    By kubotaman in forum ShopBotter Message Board
    Last Post: 12-12-2010, 08:44 AM
  2. Post Processor for Indexer?
    By kubotaman in forum Indexer
    Last Post: 07-27-2010, 12:24 AM
  3. Shopbot Indexer Post Processor
    By phil_o in forum Indexer
    Last Post: 03-07-2010, 10:24 AM
  4. First post
    By kevin in forum ShopBotter Message Board
    Last Post: 07-14-2009, 07:02 PM
  5. Artcam Indexer Post
    By patricktoomey in forum ArtCAM
    Last Post: 06-26-2006, 01:36 PM
