Yep got it and emailed you I thought (G) time to get the standoff holes setup.
thanks so much.
thanks so much.
Hi Steve
Have send a crv file to your email address - when I tried to upload file it can back invalid file. The joys of computers! Hope it works.
Cheers
Chrissy
I tried to upload it also and it came back as invalid also
how's this?
When working with files from AI, you "must" get rid of all fills and color blends.
For this for you should have only the outline of the logo with no color fill.
Obviously the concentric circles are from the color blend used and it is imbedded in a mask.
Undo the mask, kill the blend and keep only the outline.
Also, when for example you import a text object (converted to outlines), if you do not remove the fill, you will end-up with two paths on top of each other.
Hope this help.
Bernard.
thanks everyone for all of the help.
