I'm putting my ShopBot Alpha through the ringer right now. I'm cutting aluminum bar and have been running into some issues. The bar stock is 1/2" and 5/8" thick, and im cutting holes into it and trimming the edges to size. I have my feed rates and tool choices down, and am getting great cuts out of them. But there a few things im having trouble with. 1) Keeping my bits cool, and 2) how quickly they wear out. My cut file has several different cuts in it that require different tools, so each cutter is getting a break. However, each cutting tool is running for 30-40min straight before that part of the cut file is done and ready to move onto the next. I'm noticing that my bits aren't lasting much longer than a day in some cases, two days in others. I'm wondering if there are any suggestions to help prolong the life of the bit. I am using a cold air gun with two outlets on the bit/ material. and I have set the material size larger than the actual material so that before each new cut the bit has some time to cool down a little. An example is: im using a 65-025 bit (single O-flute Upcut) to trim down the edges of one piece and later cut small holes into another. This bit lasts me about 2, sometimes 3 days before its done, but each cut it runs is going through 5/8" of aluminum and taking 40 min each time.
Someone suggested programing in steps between each new cut to have the bit dip into a cup of lubricant or water to cool it down, but due to the amount of time it takes to cut each thing im not sure that will help, plus im using the cold air gun. I am under a time crunch to complete these cut outs and assemble the pieces.
