Spindles are the cat's meow for cutting on a shopbot but, my luck with bearings with HSD is quickly driving me nuts. My first spindle lasted approx. 1 year 4 months. My second spindle lasted 7 months and my third (out of the box) is doing the same thing. Maybe it is something else I am doing. Here are my symptoms / problems.
Start-up:
A serious grinding noise coming from the lower bearings
once ran through the warm-up cycle:
too hot to hold your hand on outside of spindle
during cutting:
sporadically during cutting a vibration noise / grinding noise that rivals that of running a router (actually louder than running a router) and more vibration on the part than I can sand out without changing the shape.
During the install of the newest spindle I made sure all bolts were not bottoming out (plate to spindle and plate to machine) I am within .004" in a 24" span of being lvl to the machine / table)
All 3 spindles have done the same thing once I begin to hear that awful start up grinding noise.
90% of my cuts are as follows
5/16" 2 flute up-cut
RPM: 18,000
Plunge: .5 IPS
Cut rate: 2.4 IPS
Material: 3/4 Advantec (like a combo between OSB and Particle Board but, water resistant) or 3/4" Plywood.
Things I have already tried:
new collet, new nut, new cutter (I already replace cutter around once per week.
Different diam. cutter / nut / collet
Faster feed speed = worse vibration / noise
going slow enough to burn up my cutter = less noise / ruined cutter and material
Any help advise would be greatly appreciated
Thank you,
Troy
