Results 1 to 10 of 14
Thread: Help please - with Aspire modeling issue
    Jul 2011
    Timmins, Ontario, Canada
    Default Help please - with Aspire modeling issue
    I am trying to cut half-spheres out of a 1" piece of material. 12 "pockets" in a row, each 1" diameter, by 1/2" deep (a perfect half sphere)
    I can model it with a 2 rail sweep or with the modeling tools (-90 degree, round shape, depth of .5").
    The problem is, when I do a tool path, the upper edge of the pocket is very irregular, and rough.
    Also, I would like to cut the pocket starting at the outer perimeter and cut in a circular path working deeper and towards the center, but it will only let me start in the middle and work my way out.
    Help!
    AJC
    Mar 2009
    Parts and Templates, San Carlos CA
    try this. Strangely enough, I had just read this today.
    http://fromaspiretobeyond.blogspot.c...-easy-way.html
    Hmm...I see what you mean, AJ. That is rather nasty looking even at max modelling resolution (Slowest 7x). I am not sure what is up with the toolpath either. Besides not having the ability to choose where the offset starts, the tool appears to gouge the top edge of the model - which it should not be doing.
    Send a message to Vectric support. They may have run into this before, or be able to offer you a remedy.
    David - I this is not normal & I don't see any way to machine between boundaries with a circle as the vector.
    Toolpath Sim Result:
    Jul 2006
    Hendersonville NC
    Hi Andrew,
    If the top edge roughness you are seeing is like Brady's picture, this is easily solved by creating a flat zero thickness component. See here:
    http://support.vectric.com/aspire-qu...ed-model-rough
    As for the direction of the finish toolpath, the Offset option always starts in the center and works outward. The only thing you have control over is the Cut Direction, Climb or Conventional.
    Tim
    Mar 2005
    San Jose, CA, USA
    In this particular case I am wondering if it wouldn't be faster and better to cut those with a 1" ballnose bit with a drilling toolpath
    - Randall Newcomb
    10 fingers in, 10 fingers out
    another good day in the shop
    Quote Originally Posted by rcnewcomb View Post
    Definitely.
    Jul 2006
    Hendersonville NC
    Yes, that was suggested to him on the other forum he posted on.
    However, knowing you should always create a zero thickness component when working with recessed shapes is important and will help him in the future I'm sure.
    Tim
    , Monongahela PA
    I've run into this as well and have had good results by drawing a boundary just a couple of thousandths larger than the feature. Select your feature, then shift select boundary. This keeps the tool from going out and over the edge of the feature. You may have to adjust the proximity of the boundary to the feature for optimum results.
    Quote Originally Posted by tmerrill View Post
    However, knowing you should always create a zero thickness component when working with recessed shapes is important...
    You shouldn't have to create a component with zero thickness at all...this is obscure. It should be a built-in feature that automatically & invisibly creates this 'zero thickness' component behind the scenes so that the user never has to think about.
    Jul 2006
    Hendersonville NC
    Brady,
    As of now it is what it is and I'm only trying to help AJ resolve his issue and get on with his project.
    I would suggest you email your suggestion to support@vectric.com so they can evaluate it.
    Tim
  1. Issue with V-Carve tool path in Aspire
    By willmorgan in forum Troubleshooting
    Last Post: 03-31-2016, 08:40 AM
  2. Modeling a LARGE 3D/Relief design in Aspire
    By Chuck Keysor in forum Aspire
    Last Post: 07-18-2015, 08:33 AM
  3. Modeling Help
    By cbradshaw in forum ShopBotter Message Board
    Last Post: 10-19-2011, 09:41 PM
  4. Aspire 3v Modeling Module
    By Flite-Metal in forum Project Ideas
    Last Post: 09-02-2011, 05:24 PM
  5. 3d Modeling
    By george in forum Archives2008
    Last Post: 09-26-2008, 03:11 PM
