Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Thread: small detail sander
    Garland Tx
    Default small detail sander
    Are any of you using and happy with a small detail sander? I need to get into a recess the size of a business card... I've been using a block of wood with PSA sandpaper epoxied to a cheep palm sander. I've burned it up and am looking for a replacement...
    Mar 2009
    Parts and Templates, San Carlos CA
    I have a Fein detail sander. Been at least 15 years. Still runs perfectly and sands well.
    Garland Tx
    David
    I know that Fein makes durable tools and the detail sander was spoken well of in a previous thread here... Do they make a head small enough to fit into a business card size recess?
    Jun 2012
    Ohio
    Steve, I have this Festool detail sander and I can get it in most anywhere. (Mine is actually the DTS EQ Plus, don't know if there's any difference there.)
    I've burned up a pile of little sanders, and I saw these being demo'd at Hartville Hardware. Once I tried it, I was sold.
    It hooks right up to my Festool Vac and I haven't sucked a lick of sanding dust since. It really is a beautiful thing, even if the pricetag is completely ridiculous.
    Mar 2009
    The starndard sized pad would not fit. You can modify the sanding head with a jig saw. There are also various premade heads that you can purchase.
    Garland Tx
    Festool Pad Size 4" x 6"(100 x 150 mm)
    A business card is 2"X 3.5"
    Still looking!
    Garland Tx
    I found the Kent sanding finger and it looks like it might work.. I cant verify the dimensions however... http://www.amazon.com/Sanding-Multi-Max-Multimaster-Craftsman-Milwaukee/dp/B004UJBFY2/ref=pd_cp_hi_1
    Oct 2000
    Toms River, New Jersey
    Steve,
    I've used a Porter Cable detail sander for years, with good results. the reason I chose that tool over the Feins, and Festools was because you get a bunch of different sanding profiles with the tool and it's VERY easy to cobble up custom pieces of rubber that will easily attach to it's body. NO proprietary add ons are necessary.It is very handy to get into those difficult places on a boat that won't accommodate other sanders. BUT I have never used it for 100%duty cycle type of work where I did batches of parts all day long. Maybe if someone else on the Forum has run it all day they can comment on it's performance.
    "Share your knowledge. It is a way to achieve immortality"...The Dalai Lama
    "Nothing is really work unless you would rather be doing something else....." Sir James Barrie
    I have the Fein but have used the Harbor Freight unit also It is a lot cheaper than the Fein but it does the job. Don't want to take a $300 tool to a trade show where it would be the target of theft do I got the $20 HF unit.
    Nov 2009
    The Festool Deltex is the only one that works. Mine has been a lifesaver.
    http://www.festoolusa.com/products/s...er-567856.html
  1. I need a Multi Tool which one? (detail sander type)
    By gundog in forum ShopBotter Message Board
    Last Post: 10-18-2016, 12:44 AM
  2. Detail in Aspire
    By butch in forum Aspire
    Last Post: 04-15-2009, 09:58 AM
  3. Texture detail
    By brucehiggins in forum Archives2008
    Last Post: 09-17-2008, 09:38 AM
  4. Corner-radious bit detail
    By tree in forum Part Wizard
    Last Post: 06-24-2007, 08:35 PM
  5. Can a Shopbot produce this level of detail?
    By luger in forum Archives2007
    Last Post: 03-14-2007, 08:11 PM
