A friend/neighbor asked me to make a wooden wagon wheel similar to those used on the Pioneer Wagons that came west in the mid 1800's.
He salvaged a mostly decayed wheel buried in concrete in order for me to get dimensions and an idea what it looked like.
We will improvise on certain features because it will be used for decorative purposes only.
The Wheel Hub will will be split into staked layers of wood and the middle halve of the Hub will be split to capture the spokes, then the upper halve will be placed over the split hub, doweled and glued.
The Felloes will also be split and segmented as shown on the attached image.
Using Aspire to model and generate the assembly concept was a great help. Of course I have separate Model files for each component generated by 2D cutting files, then I created Models from the toolpath image and pasted them into a separate Aspire assembly project file.
Hope this all makes sense and the image should be helpful.
The Wheel diameter is 43.50 inches. A steel band will be shrunk fit to the wooden segmented Felloes.
George D Kelly
