Results 1 to 8 of 8
Thread: Installing & squaring the Z axis..
    Jul 2006
    Default Installing & squaring the Z axis..
    Per the instructions, I loosened the 10 5/16" bolts that hold the blue frame to the aluminum extrusion sides. I then installed the Z axis and tightend down the 1/2" bolts and then tightened the 10 5/16" bolts.
    According to the assembly instructions, you're supposed to do this in order to prevent distorting the extruded side plates.
    The problem I'm having is that when you tighten the Z axis bolts and then re-tighten the 5/16" bolts, you've effectively(sp) eliminated the room needed to adjust the Z axis to make the direction that is perpendicular to the X rail parallel with the table surface. The only way I can see to rectify this without diverging from the instructions would be adjust the alignment of the Y car by fiddling the eccentric nuts on the rollers until that part of the Z axis is correctly aligned.
    There was an orange tag on the Y car that reiterates the importance of losening these 10 bolts, so I really don't want to second guess these guys and risk deforming the extrusion.
    On another note I've got the Z axis installed in such a way that that oval side cutout is even with the Y car sides in order to make fitting the backing nuts for the mounting. However, the picture in the book shows the Z axis with one open hole above the top surface of the Y car. Is the picture inaccurate (the Z pictured has more holes than mine?) or have I mounted my Z axis too low?
    Thanks all!
    g.
    Jul 2006
    Ummm. Help?
    Feb 2006
    , Canyon Lake TX
    Gene,
    I think you're one of the first to have the extruded aluminum sides, so you lost us all with that question.
    About that z height.... I would place it as high as you can. When you start adding spoilboards, you lose Z-travel fast.
    Wish I could help more. Good luck.
    Jul 2006
    Thanks Scott. Too bad my original post was deleted. I'm not amused. Can't do diddly about it though, so there you are. Have a nice holiday!
    Oct 2006
    Norwell Ma.
    There are 4 holes when mounting the Z I am in the process of installing it now and the instructions do not tell you which ones to use.
    Jul 2006
    Leonard, if you look at the side of the Z axis, you'll see holes running down the side for mounting the axis. If you mount the Z between the rails with one of those holes visible above the Y car itself, you should be ok.
    I don't have a picture handy to show you what I mean, but if you look in the book where it talks about the Z installation, there's a picture that shows the Z axis with one hole showing above the Y car.
    I hope this helps!
    g.
    Oct 2006
    Norwell Ma.
    Thanks Gene I think if you had a project the needed more hight you could move it up higher?
    Apr 2004
    Austin TX
    I think the bottom 2 holes on the Z frame are meant to be used. They are the most difficult to attach the nuts to, but give you the most Z travel. I just finished remounting mine. The pictures and instructions are marginal during assembly.
  1. Squaring z-axis on Buddy
    By pyrodenis in forum ShopBot Buddy
    Last Post: 07-03-2014, 09:38 PM
  2. Z axis squaring help?
    By JimFabLabFulton in forum PRS Assembly
    Last Post: 12-05-2013, 10:21 AM
  3. Looking for tips for squaring the X-Y Axis
    By ampd in forum ShopBot Buddy
    Last Post: 06-03-2009, 10:04 AM
  4. Squaring the Y car to the X axis
    By sagreen83 in forum Archives2005
    Last Post: 06-12-2005, 06:47 AM
  5. Squaring Colombo Z axis
    By stargategfx in forum Archives2004
    Last Post: 04-16-2004, 01:49 AM
