Results 11 to 20 of 22
Thread: Another Textured Panel Help Request
  1. #11
    Aug 2012
    Durham, NC
    Quote Originally Posted by Mayo View Post
    When making panels like those, do you have to do anything to the back of the panel to keep it from cupping or warping?
    And would this vary depending on if the material is MDF or urethane foam?
    I have seen some samples from other companies. That stuff was 1/2" MDF laminated to 1/2" plywood. That seemed like a pretty damn good idea to me.
    Mounting is a concern for me. I'm leaning towards simply mounting to the drywall in my house with Liquid Nails... That does have a small problem of being hilariously permanent...
  2. #12
    Jun 2007
    Hampton Roads, VA
    Quote Originally Posted by jdanforth View Post
    I would really like to make some 4x8 panels covered in the kind of textures seen in this ShopBot promo photo.
    I know that there are a dozen ways of going about this process but I'm hoping someone can show me a quick tutorial for recreating the texture shown at the top right. I have access to an Alpha, Aspire, Cut3D, and Cut2D via TechShop.
    I have seen tutorials for doing this in Rhino but I'm hoping there's an easier way.
    Thanks!
    Here is a < 5 minute tutorial in aspire 2.5 on how to make the upper right panel + a bonus panel for good measure.
    I think I will make these panels for the mid atlantic bot gathering at Angus' shop. Anyone interested in seeing them?
    HTH,
  3. #13
    Aug 2012
    Durham, NC
    Quote Originally Posted by khaos View Post
    HTH,
    This was tremendously helpful, thank you!
  4. #14
    Jun 2007
    Hampton Roads, VA
    You are most welcome.
  5. #15
    Dec 2011
    Wash DC
    Joe, Very well done. Many thanks. Thats a easy to follow, fantastic explanation of 2rail sweep.
  6. #16
    Jun 2007
    Hampton Roads, VA
    Quote Originally Posted by johnh View Post
    Thanks. Its very powerful especially when used 'out of the box'
  7. #17
    Nov 2007
    mcgrew woodwork, columbia south carolina
    150.00 per sheet, 4 x 8 (150/32 = 4.68 ) i get 35.00 finishd and installed. 32 x = 35.00 =1120.00 per sheet,
    Charge a bit less for 1" hdf 3/4" mdf, yet always lay up a phenolic backer on sheet, just a few bucks yet no warp !!
    grants files look great and i will be using them !!
  8. #18
    Jun 2007
    Rutherfordton, NC
    Thanks for the compliment, James! I look forward to helping you with anything you need!
    Phenolic backer eh? That sounds like a good solution - what type of phenolic do you use and in what thickness, if you don't mind my asking?
    Grant
  9. #19
    Nov 2007
    backer sheet is common in military and architectural specs and offsets the warp when a sheet is unbalanced
    http://www.wilsonart.com/productlib/.../BackersTD.pdf
    we have also done it as simple as spraying laquer on the back !
  10. #20
    Jun 2007
    Rutherfordton, NC
    Thats really useful info, thanks!
  1. textured background
    By jsmithconstruct in forum Sign Making
    Last Post: 08-22-2013, 04:26 PM
  2. More on Textured Panels
    By associated in forum VCarvePro and PhotoVCarve
    Last Post: 08-06-2008, 04:05 PM
  3. 3D textured HDU substrates "Ready to Go!"
    By tuck in forum Archives2008
    Last Post: 04-29-2008, 08:12 PM
  4. Textured Backgrounds
    By joe in forum Archives2005
    Last Post: 10-17-2005, 12:24 AM
  5. Textured Sign Background
    By Dan_Tech@Charter.net in forum Archives2004
    Last Post: 01-24-2004, 05:44 PM
