Results 1 to 9 of 9
Thread: How do I copy this?
    May 2005
    Classic Playfield Reproductions,
    Default How do I copy this?
    I am making a replacement part for a Pinball machine and I have done many before but have always used a straight 2d cut and now have a feature that I still may be able to do 2d but I am unsure what's the best way to do it. I'll attach a picture but essentially I have a 1.2" hole all the way through the wood and I need a bevel from about .2" down into the hole back up to the surface, The top of the bevel where it again meets the surface extends about .75" from the edge of the trough hole. It's essentially a large saucer that would cause a pinball to go to the center and drop onto a switch.
    I have 1/4" round overs and several 60 and 90 Sign making bits and even 1 or 2 120 degree .75" bits. What's the best combo to use?
    Mike
    You can do it 2D, using the shape of the cutting tool to provide the negative relief, or 3D in a program like Aspire.
    From the looks of the shape, a 120 may cut too deeply at its shallowest depth - you might have to go 130-150 deg to get the shape you need.
    Jun 2004
    Springfield Mo
    Default copy
    Seems like you would cut the 1.2 inch hole first and then do a profile on the same line .2 inches deep with probably a 90 degree bit.
    Does it have to be exactly the same taper or does "just close" work ?
    Nov 2011
    Northern Michigan
    Mike...
    If you are feeling ambitious, you can do this with a ballnose and some hand coding to set the depth and diameter of a repeating "CP" command. Save as a C# file and use a "drill" postP to locate and run.
    Gary Campbell
    ShopBot Orphan (No PM's)
    GCnC411(at)gmail(dot)com
    www.cncseminars.com
    May 2005
    Brady; I think you're right about the 120 being too high of an angle but I was hoping that by cutting 2-3 paths with a gradual depth increase I could approximate the angle I need. I looked and just can't find a more shallow bit. So I am stuck making something close enough I guess
    Curtis; Yes, the 1.2 hole gets cut first with my upcut spiral and then I figured a bit change would be required. The 120 degree bit is a little too high but I was thinking 2 or maybe three passes spaced properly might give me something close I could sand out.
    Hey Gary; Those two air drill setups you sent me are still working hard. They have run many hundreds of hours since I got them. Is there a way to figure out my step out and step up from the edge, other than to sit down and write each line, I suppose it wouldn't be that hard but I'd have to write a line for each larger circle stepover, correct?
    Nov 2011
    Northern Michigan
    Mike...
    If you send me the geometry of the dish in cross section, showing depth and diameter, I can be more specific
    gary.campbell(at)shopbottools(dot)com
    GC
    Gary Campbell
    www.cncseminars.com
    Mar 2005
    San Jose, CA, USA
    If you have Vcarve/PartWorks you can use a fluting toolpath. See the attached example:
    Attached Files Attached Files
    - Randall Newcomb
    10 fingers in, 10 fingers out
    another good day in the shop
    Interesting approach, Randy!
    Now thinking about it, I'm pretty sure you can do this in SB3 using the Extruder tool with Arc option.
    May 2005
    I think I figured it out. It's not pretty. Gary gave me an idea. I just planned on using a 1" Core Box bit. Then I measured the distance I had to cover, decided 8 passes would produce a smooth slant. I divided the distance into 8, then offset inwards from the outer circle that 1/8 distance, in 8 steps. Next I just divided the Z axis distance by 8 and manually did a cut along the vector for each offset line, gradually stepping down by 1/8th of the Z axis distance each time.
    Works perfectly!
    Thanks for the inspiration and ideas!
    Mike
  1. Copy file help
    By propellers in forum Archives2007
    Last Post: 05-21-2007, 06:01 PM
  2. C copy direction
    By geoff in forum Archives2006
    Last Post: 11-16-2006, 09:06 AM
  3. So... what now? Copy 3D object...
    By harryball in forum Archives2006
    Last Post: 09-11-2006, 11:54 AM
  4. Copy Machine
    By jay in forum Archives2006
    Last Post: 03-19-2006, 09:48 AM
  5. Need Copy machine help
    By G. Ayers (Unregistered Guest) in forum Archives 2005
    Last Post: 12-28-2005, 04:47 AM
