Results 1 to 7 of 7
Thread: T-Mold Groove in Round Table Top?
    Jul 2012
    Tampa
    Default T-Mold Groove in Round Table Top?
    Is there a way to use the shopbot to cut a T-mold groove in a round table top?
    I have been doing them on the regular router table, but 30% of them end up off center.
    yes there is but it is a little bit of trial and error. You also have to have the right bit
    Aug 2008
    Cocoa, Florida
    I use a slot cutter on a bearing with a hand router works perfect every time,On the bot a slight variation in depth can cause it to be off Seems like a harder way to do it and come out right.
    Apr 2011
    Amber, NY
    In my experience the best way would be a good fixed base router and a bearing bit. The router will follow the variations in the material. On a router table, the surface of the table in conjunction with the plywood may cause an issue. In your case it's unsatisfactory results.
    Regards and Luck
    Randy
    I don't always indulge in evil scientific research...but when i do. I make the parts on a ShopBot.
    Jul 2012
    Tampa
    I fixed this by mounting 2 pieces of "angle aluminum" right by the router exactly 3/4" high. This keeps the wood exactly flush with the table.
    Also, by getting a new T-groove but to cut EXACTLY as deep as I needed. (reduces the "fight" it was giving)
    Cuts like butter now. 10% of the table tops will have a scratch on the top from the aluminum since I am using prefinished birch.
    But a lot easier to save the finish on the top than to ruin 30% of the tops I was cutting
    Jan 2008
    "scratch on the top from the aluminum " Have you tried a small strip of clear packing tape over the aluminum? I have problems sometimes with my band saw table marring a finish and I've tried just putting down a couple of strips of tape for the material to slide on and that seems to help. Just a thought, glad you got the thing working good anyway. Russ
    Jul 2012
    Tampa
    Quote Originally Posted by chiloquinruss View Post
    this is a good idea
    I will try that
  1. What is a V-Groove Bit in Fusion 360?
    By Riptide369 in forum Autodesk Fusion 360
    Last Post: 01-20-2018, 11:04 PM
  2. Trouble with round pockets not cutting round
    By Dick in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 11-17-2012, 08:50 AM
  3. V Groove....LARGE
    By sevans in forum Sign Making
    Last Post: 07-10-2012, 10:27 AM
  4. 3d round table
    By fabrun in forum Folder 2010
    Last Post: 11-26-2010, 01:15 PM
  5. V groove bit
    By Greybarn in forum ShopBotter Message Board
    Last Post: 11-14-2010, 07:50 PM
