trying to make and arch raised panel to match some raised panel doors
trying to use 2 rail sweep in aspire with no luck
Should be able to to that, what, exactly, is the issue?
Screen shots are a good way.
the outside line is the overall size
the inside line is the cut out where the panel will go
and the outer line is the profile of his bit
Randy,
Go to node edit mode and make sure that the outer and inner lines start in the same corner.
Make sure that CONNECT RAIL NODES is checked
You may have to flip the direction of one of the rails.
You may have to flip the direction of your profile.
This should get you most of the way there.
D
