Does anyone have an issue with getting a smooth cut with 3/4" Columbia pure bond with the link? I get these bulges along the entire length of the cut.
I cut 90% through in climb then all the way through in conventional. After edge banding these bulges are very noticeable. Especially with PVC edge banding. Somewhat noticeable with real wood veneer.
I use a 3/8" centurion mortise compression at about 5-6ips.
The only remedy I know of is to trim off about 1/32" on the table saw. See attached drawing for further explanation.
