I have a 2007 PRSalpha 120-60-8, 4hp spindle, version 3.6.44 with Artcam pro 2009 sp2a build 183 and windows 7. I believe the machine has less than 200 hours of usage.
The issue I have is when I move the X car from zero left corner with the key pad or running a file with an air cut, approximately the first 36-inches of travel is a little noisy, with chatter and vibration (hard to explain). Then in the center part of the machine the X car runs smooth all you hear are the motors (Model ASM98AA-T7.2) like it should be and then the noise starts back up again for approximately the last 18 inches at the opposite end. I have been dealing with this issue for the past few weeks and have tried several things.
- Rail spacing is correct (77.812’’ outside to outside).
- Replaced all pinions, old ones did not show much wear.
- While the motors were removed, the car moved freely with no binding or noise very smooth.
- Cleaned racks and all new grease.
- With the bot powered up, I can move the car .005’’ in each X direction with little effort and it makes a clicking noise. I tried to tighten the pinion into the rack on both ends and it did not make any difference.
- All bolts, screws, set screws are tight.
- I ran Gary Campbell’s Program (Tuning up the PRS Gantry). It is perfectly square.
- I checked all the wiring from the motors to the controllers, it all seems to be fine.
- The Bot is in a climate-controlled environment. Most of my work is 3D using a 1/8 ball nose.
Still noisy I am not sure what to do next. Has anyone ever adjusted the backlash in the motors?
Thanks for any assistance you may be able to offer.
