I can't find a file to cut a 5x8 vacuum board.
what do i do? I'm a first timer with cnc
Jim,
Check out http://www.shopbottools.com/LabFiles/bradyvac.htm . I used this to generate my file . I created a plenum with a grid about 1.25" squares to distribute vacuum readily . The file that comes with the bot it much to course I think but will also work . I created one file and ran it 4 times for 4 zones using the following Shopbot file :
'Start of master file Part File to ceate 4 grids from brady vac files
M2, .5,.5
FP, myBradyVac2.sbp,,,,,2
M2, 48.5,.5
M2, .5,24.5
M2, 48.5,24.5
I found the file that comes with the bot but I don't know how to resize it to run on a 5x8 table.I,m sure it is easy but i need a sb for dummies book I guess
