Thread: Swapping prt motors???
    Aug 2004
    Default Swapping prt motors???
    Ive damaged a motor on a prt about 6 years old. I have the indexer and was thinking of swapping the motors to get me through the next couple of days. The indexer has a .25 step motor where the axis motors are .5 step. Can i reconfigure to make this work, or am I sunk???
    Kevin
    Dec 2008
    , Richmond Tx
    I don't see why not. I would use it for the Z. Under vaules click unit values to change the speed. I would think double the current number there would fix you up. Just don't put it on the X where it has a different motor on each side of the machine. Double check that one inch is actually one inch when you are done.
  1. Swapping X and Y on a PRT
    By gripus in forum ShopBotter Message Board
    Last Post: 12-22-2013, 09:34 AM
  2. motors
    By larry_k in forum Indexer
    Last Post: 08-24-2013, 04:21 PM
  3. Mirrored assembly - swapping X motors?
    By minigoogoo in forum Cabling Options
    Last Post: 09-06-2011, 11:28 PM
  4. Speed and Distance Problems when Swapping B and Y axis'
    By jim_stadtlander in forum Archives2008
    Last Post: 05-26-2008, 08:03 PM
  5. Alpha 7.2 motors or PK299-F4.5A motors?
    By richards in forum Developers
    Last Post: 11-29-2007, 01:18 PM
