Is this something I need to watch for manually in the 3D tab simulation?
you have to space your parts out far enough apart to allow for the diameter of your bit plus some material to keep the blank together.
I created a new PW design with an "L" for x/y guides, a circle over the vertex, welded the vectors, and then trimmed the hypotenuse that was added by the weld
Whaaaat? I think i understand what you said...did you just say you made a 90 degree corner for material?
I found that my cut depth was too shallow.
Do you mean that you, for example are cutting 3/4 plywood, you set your depth of cut to .75 only to find that you have not cut thru your material?
When this happens to me, what i do is i just guess how much more i need to cut to go thru the material by going back to x,y 0,
then lowering my bit by doing MZ0 lowering the bit to the material surface 0
(while router NOT running)
then clicking the Z down maybe .10 and RE Z'ing to that lower height
then rerun the file, it will cut down .10 deeper on the ending but if you have tabs you need to be careful.
The idea is all you are having to do is re Z, rerun file
Words of Wisdom:
