Results 1 to 5 of 5
Thread: X & Y zero using Zzero plate
    Sep 2009
    Environamics, Inc., Charlotte NC
    Default X & Y zero using Zzero plate
    I know this has probably been discussed many times before but I cannot locate the information I need in the archives.
    I want to zero X and Y axis using Zzero plate and compensate for the cutter DIA at the same time. Is there a program out there to do this?
    Thanks in advance
    EdT
    Mar 2008
    Radford VA
    Ed - Yes, there is a special program that you can put into your custom cut files that will do this. I made my own Z zero plate. It consists of a 1/2" thick plate, that I machined flat on both sides to be as exact to 0.500 as I could get it. Then on two sides, I bolted some 1/8" thick aluminum that extends about 1/4" below the thick plate and also extends about 1/2" above. This way I can sit my plate on the corner of the material and the bottom lip of the jig aligns it. I first run the Z zero program to set the zero (you must modify the routine for the 1/2" thickness). I then run the special routine that sets the X and Y. The routine first moves in X and touches off on the side, then it moves back and then touches off in Y. Then everything is zeroed at the corner! Let me know if you need a copy of the custom cut file.
    May 2005
    Londonderry New Hampshire
    Brad,
    I would be interested in a copy of the file...thanks in advance.
    Dick
    ou can download the file open it into your SB editor and the save as a SB file.
  1. Help find lost Zzero plate routine
    By MDCochrane in forum ShopBotter Message Board
    Last Post: 02-03-2014, 01:24 PM
  2. ZZero plate issues
    By dave swanyek in forum ShopBotter Message Board
    Last Post: 08-19-2012, 07:11 PM
  3. zzero plate variable?
    By fozzyber in forum ShopBotter Message Board
    Last Post: 03-06-2011, 02:02 PM
  4. Zzero plate
    By mikelush in forum Archives2008
    Last Post: 01-25-2008, 04:03 PM
  5. Making a ZZero Plate
    By john_r in forum Archives2006
    Last Post: 04-29-2006, 04:17 AM
