Lauri- I suspect you have a misunderstanding about how zeroing and bit changes are set up. The SB3 program does the zeroing not Partworks. So no amount of reading PW docs will make any sense!
When you hit C2 to zero your bit on the ZZero plate, what SB3 does is run a series of files that ends up running the file "C:\SbParts\ZZero.sbc"
You can edit ZZero.sbc and make it do whatever you want. That is where you need to put your delay request.
How to add the delay? The documentation is thick at first, but you will find the file "ProgHand.pdf" in the "Program Files\ShopBot\developer tools" folder. It explains how to customize your machine more than you ever imagined.
There is a pause command, and now you have to study the code (not a trivial thing) to figure out where you need to put it to get the effect you want, then make the change.
You can make it work any way you need. I have heavily modified mine.
Its another level of complexity most people never get into. But fear not, its not all that hard or I could not have done it. And its very rewarding!
Good luck!
D
--Greg Westbrook
