anybody tell me why all of a sudden my #2 input light is off?
cant properly zero my z and my drill
Broken wire or loose connection?
what would i look for due to number 2. what would that make u think what wire loose
This is the input for your X axis proximity switch. Remove it from the blue terminal block and re-seat it. Do the same for the proximity switch wires going to ground and 24v, making sure all is connected correctly.
Then unscrew and remove & re-seat the X-axis prox connector (at the prox switch) and see if that clears it up. If that doesn't change anything, I'd say you either have a broken wire in the X prox wire bundle or a bad prox switch.
