Results 1 to 7 of 7
Thread: Chipbreaker / Finisher Bit Size
    Nov 2011
    Nashville TN
    Default Chipbreaker / Finisher Bit Size
    We have a 48 x 96 PRS with the 2.2 hp spindle, ER 25 collets. Typically I use a 1/2" 2 flute chipbreaker / finisher for most hardwoods using multiple passes with a final clean up pass.
    Will the 2.2 handle a larger diameter bit, say a 5/8" or a 3/4". I know they make collets in the larger sizes but didn't know if it's a good idea or not.
    Stephen
    Feb 2004
    , Cheltenham
    How deep are you cutting?
    I use 16mm (5/8) x 170 cutters 2flute to cut 130mm deep (Bubinga - it JUST about works...), 14mm insert straight incrementing in from outside up to 60mm deep (works a treat) but up to 20mm I use 10mm dia cutters. Horses for courses.
    R.
    Nov 2011
    Nashville TN
    R,
    Usually it's just 3/4" or 1" material, typically free form geometric designs. I usually go about 1/4" per pass with about .03" offset from the part then a full depth final pass cleaning up the .03". Mostly in hardwoods, oak, cherry, walnut.
    Your cutting 130mm (5 1/8") deep? How many passes? Are you on a 2.2 or larger spindle?
    S.
    Oct 2000
    Atlanta GA
    The 2.2 hp spindle should have no problem with a 5/8" or 3/4" bit, you probably want to keep the RPMs on the low side. We use a 2 1/2" diameter spoilboard surfacer at 12K RPM to cut up to 1/8" deep in hardwoods.
    David Buchsbaum
    Beacon Custom Woodwork, Inc.
    dba Atlanta Closet & Storage Solutions
    404-309-9146
    david@atlantacloset.com
    atlantacloset.com
    beaconcustomwoodwork.com
    Dec 2009
    WiLL PACK, LLC, Franconia NH
    David - what speed would you normally run that 2 1/2" surfacer bit - that's cutting 1/8 deep?
    Tom
    Dec 2009
    David - I meant what feed rate?
    Tom
    Oct 2000
    Atlanta GA
    4 ips for hardwoods up to 1/8" deep, maybe 3 ips for a delicate or critical surface.
    8 ips for surfacing the spoilboard at .014" deep
    David Buchsbaum
    404-309-9146
    atlantacloset.com
  1. SB3 'Material Size' different than Aspire 8.5 'Job Size and Position, how to fix?
    By carolinasmith in forum ShopBot Control Software v3
    Last Post: 10-06-2016, 08:35 PM
  2. Drawing size does not match cut size.
    By tracys in forum ShopBotter Message Board
    Last Post: 09-30-2013, 01:22 PM
  3. Old Motor Shaft Size VS New Motor Shaft Size, Pinion and Rack...
    By rb99 in forum ShopBotter Message Board
    Last Post: 12-03-2012, 08:33 PM
  4. Lying about bit size to affect part size
    By sbd1 in forum ShopBot Control Software v3
    Last Post: 06-10-2012, 02:30 PM
  5. Cut size not equal to part wizard-toolpath size
    By bob_schroeder in forum Archives2007
    Last Post: 11-18-2007, 01:16 PM
