Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: UPS Battery Backup?
    Nov 2008
    , On
    Default UPS Battery Backup?
    I have searched but no luck. Are UPS backups recommended and if so how big, what setup?
    I am looking to protect from those power flickers that happen sometimes.
    Oct 2005
    Olympia, Washington
    I run one on all my computers in the shop. I don't have one on the ShoBot it self but on the last power bumps we had the bot kept running through the minor power bump until I could shut it down. I got mine at Costco I think they are the 1500 va ones. I also have one on the desktop shopbot I have and tested it out running the spindle and moving the carriage around and it worked fine said I had about 5 minute of power left on the battery during the testing. By installing the UPS I also increased my connection speed from about 72% up to 80%.
    Ron Moorehead
    R&S Design
    ShopBot PRS Aphla 48 by 96
    Laserpro Explorer 30 watt
    Universal Laser 50 watt
    3D printer
    Mar 2009
    Pope Valley CA
    Yep - a good UPS makes a great line filter...
    Ron Sloan
    Mar 2008
    Tulsa Oklahoma
    I will chime in on this one..
    Rons (Sloan) commented about the UPS as a line filter. Yes indeed. A REAL UPS is about the best line filter you can get.
    There are two kinds of units a "UPS" and a "SPS".
    A UPS (Uninterpretable Power Supply) is a system where the load runs off an inverter 100% of the time. There is a battery charger/maintainer which supplies the inverter and batteries to keep them charged. This kind of unit is more expensive than a SPS. It will interrupt itself when the batteries run down, but they are intended to get a generator online and start recharging the batteries. The load is on the inverter 100% of the time, or its not a UPS.
    A SPS "Standby Power System" is an inverter with a relay so when the power goes off, it quickly switches the inverter on, and it takes over the load. The load runs off the utility power almost 100% of the time and the battery charger/maintainer is very tiny since it does not need to be able to supply the load also.
    A SPS is not as good as a UPS, but costs a lot less. What you would purchase at a office supply is most likely a SPS.
    It is possible to purchase either a UPS or SPS large enough to keep the entire shopbot running but probably, though its not cost effective for most people. Backing up the computer like Ron (Moorehead) does is a great compromise. A very small unit will backup the control computer and allow you to note the line to continue the cut on when the power comes back. The SPS or UPS lets you shutdown the computer and save your files.
    A very small unit will do the computer protection job for a very reasonable cost.
    One alternative to all this is use a laptop computer with a good battery as the control computer. It is a UPS built-in. The charger keeps the battery going, and the battery keeps the computer going. No glitch when the power goes out. The Shopbot however is another story.
    D
    --Greg Westbrook
    Feb 2010
    SOUTH CENTRAL COLORADO
    I know this is a 2 year old post, but truth is i did not know what a ups was until about a month ago. I live in the sticks and we have more than our share of power blips. Generally they are only for a few seconds, but enough to shutdown the computer, loose your zero and shut down the the shopbot buddy. So i am assuming that the ups would keep my computer live. I am also assuming that the buddy would still be running, but i would imagine putting it into a pause and noting line, x, y and z would be important. that way when the power is restored i could continue where i left off. Now tell me where i am wrong and if not what unit would be best for the buddy.
    All true, but there is a caveat...You want some mechanism in place to pause the machine if the power goes out. It takes a lot of power to run the router and drive motors, plus computer. Go with the largest UPS you can afford if you aren't able to get to the machine right away.
    The UPS will also buffer the power in your building and smooth out line ripple. Think of it as a big drum of electricity, with your line power pouring in at 60 pumps per second. If gravity fed from the bottom of the drum, there is no ripple...which is a good thing for electronics. UPS would be good as a line conditioner if you planned on running your bot off of a genny...and some generators have a line conditioner built in now.
    It would be possible to setup your tool with a relay that monitored a small electrical load that was connected to the main power of the shop. On input (power goes out & relay tripped), the machine could be told to pause, shutting down all movement and power to the router. There are probably other solutions to this, but this is what immediately comes to mind.
    Feb 2010
    Thanks. My Buddy is setup in the corner of my garage and i only cut when i am home. I can only guess that the bot would not have to run more than a minute before i could get to it and hit the pause button.
    Like i said earlier i am really just learning about the ups.
    Oct 2014
    La Crosse, Wisconsin
    I went with a CyberPower PR2200LCD. Its probably a bit overkill but we intend to take the desktop to craft shows etc. Never know how clean or stable the power might be. My testing shows that with my laptop, desktop, and 60 watt light plugged in ill get close to 30 min. Of run time after a power failure I'm running a spindle not an add on router. Even at home its comforting to know I have a good clean consistent true sign wave power supply to the Bot. A bit expensive, close to $800. Best price was found on Amazon
    http://www.cyberpowersystems.com/pro...pr2200lcd.html
    Feb 2010
    I am still in a learning curve Maverick. My buddy plugs into a 20 amp circuit. So does your model plug into a 20 amp circuit or 15.
    Feb 2010
    Default cyberpower
    I spoke with cyber power this morning. Of course the guy did not know what a cnc router was which is ok because i dont know what a ups is. but i am learning. This is the model that plugs into a 20 amp circuit. CyberPower OR2200PFCRT2U.
    Before i drop 400 on this can someone tell me where i might be messing up.
    The weather here is clear and beautiful and we have not had a storm in days. But while i was typing this there was a blip in the power and my new desktop ups kicked in for the first time. This would have shut the bot down had it been running.
  1. Copy files and backup settings
    By khaos in forum Developers
    Last Post: 08-23-2016, 12:39 PM
  2. Do You Backup?
    By harryball in forum ShopBotter Message Board
    Last Post: 12-07-2013, 09:10 PM
  3. Backup UPS...
    By harryball in forum Variations & Modifications of ShopBots
    Last Post: 03-14-2010, 02:19 PM
