I CAUGHT YOU CHEATING!!!!! One of your legs in the back was not the same size so you stuck a slab of wood under it! Does the customer get that or is it listed as an optional accessory?
Nice work......(as usual!)
Words of Wisdom:
Actually Jack, I still have to trim the legs... but my shop floor is so out of whack... I am surprised I managed to get 4 of 5 sitting without shimming! I had to move it around quite a bit.
The guys who poured the slab (it was done back in around 1980, my building was originally put up to store old aircrfat parts for Beaver's, Twin Otters, etc old bush planes flown by a local charter) didnt take a lot of care to level it out. All my machinery is sitting on shims.
I was going to put a 6th under the front center but I dint think it will be needed.
Well, I have a few photo updates. Yesterday, I filled the cracks/voids. On various other similar projects I have done a few different things... keys, wedges/glue and this method - filling the cracks and voids with an epoxy/dust mix. I use West systems resin and the fast hardener (6 hour set time). I first brush in a thin coat of resin and let it soak in, then mix the resin with some sawdust and use a putty kife to get it to fully fill the crack. When dry, sand and its all smooth and very strong. I didnt think a key was going to look right in the area of the crack, and I wanted the crack to be structurally 100% sound. Epoxy will do just that!
I sanded the whole bench with 100, and 120 with the ROS then hand sanded with 120, 150 and a sanding sponge. I brushed a coat of Deft Danish oil (Natural). I will be finishing the bench in a satin catalyzed lacquer.
Final pics when it is finished. I think the cherry has some awesome grain, some figure/waviness and the colour pops with the application of the oil.
Also, I trimmed the bottom of the legs to both sit flat, and set the seat height at 18" in the front, and 17 1/4" in the rear. I like a slight back angle, for comfort.
Since we don't have a like button... I made my own.
There is something about the beauty of natural wood that just appeals to me, that is real nice Andrew...
Words of Wisdom:
