I've moved away from this thread, as the table and ShopBot are levelled (for now!).
I did say in that earlier thread I would remark on the Manual, but it has since occured to me that, as my 'Bot is a Hybrid Alpha/PRT96, there is nothing useful in pointing out the problems, as they will apply to no one else.
One thing I will say. If you have problems, read the manual, most of it is in there somewhere. Like all modern technology, it's finding that somewhere which is difficult.
One thing I did experience problems with was following the Assembly Manual section through to the section on 'Taking her out for a trial run...' without reading the rest of the manual, or rather the Quick start Tutorials, and parts of Users Guide, The Big Picture.
Connecting was a problem, solved so far only by using me 'biggy' Windows XP 2gyg + computer.
My smaller, older Pentium II will not connect....yet!
So the first command I tried, as per the manual, was (MZ)-1 no problem.
My second test (MY)3 or (MY)75 in my millimeter case sent the Y carriage crashing into its stops!
And before you ask yes I was in mm not inches.
Then I couldnt persuade the Shopbot Y back beyond the middle of the carriage.
Using (K) and the arrows to move around, it sounded like a sewing machine, any move commands sounded like an automatic car driver using a shift stick for the first time. Tried the settings on page 5 of calibrating the shopbot PRT, it did not like that! Tried the settings on page 117 of the user guide. Returned to the same problems. (Z2) 0,0 then use the arrows to move x away from zero, the measured distance of 1910mm instead of the 300mm indicated, (JX) 0 and it only came back halfway.
At that point I stopped, brought the computer home, and found something had eaten the BIOS and network card (co-incidental they said in the repair shop, nothing to do with operating the ShopBot software).
Back again today I found I could reset (UR)to all the 'original' settings.
Did this and cured the problems.
Then, still without a router bracket, I taped on a pencil and drew a circle
Now Brady said something in the other thread to the effect 'stop fussing and start cutting'. It aint that easy when doing it the first time. I understand experienced ShopBotters getting frustrated and bored by newbies showing there ignorance. Maybe there should be a thread for newby problems alone, then if your not inclined to get involved in basic stuff you can ignore those posts. As for me, I will always be sympathetic to the tenderfoots.
Now to solve the 'old' computer connection problem
............Mike
