Results 1 to 6 of 6
Thread: DT spindle RPM vs frequency chart
    Jun 2006
    Santa Rosa CA
    Default DT spindle RPM vs frequency chart
    I put together a RPM vs Frequency chart to work with the VFD display on the DeskTop. Thought someone might find it useful.
    Ed
    Attached Files Attached Files
    Mar 2008
    Tulsa Oklahoma
    rpm = freq * 60
    --Greg Westbrook
    Dec 2012
    Strathfieldsaye, Australia
    Thanks, Ed. That's a nicer version than the one I had put together. As I am in Australia, and for others on 50Hz, here's the 50Hz version.
    Lenox High School, Lenox MA
    A while ago someone posted a setting so that your VFD will display in RPM. I changed it on my VFD. If I can find it I will post. Maybe someone else has it handy.
    I found my notes on changing to display RPM
    Changing the VFD Display
    Before beginning, it is assumed that the user knows how to navigate through the Yaskawa VFD interface. If this is unclear, please refer to Programming the VFD for ShopBot control on page 10 of HSD Manual (SBG00318070814HSDSpindlePRS&PRTalpha.doc) and page 9 of the HSD Manual (SBG00323071014HSDspindlePRSPRTstandard.pdf).
    • Turn the ShopBot Control Box and spindle power ON.
    • Press the RESET button on the left side of the Control Box. This action will turn the VFD ON.
    • Press the DSLP (display) button on the VFD keypad to scroll through the modes until PRGM (program mode) is illuminated. This will display a parameter number.
    • Use the Up or Down Arrow keys to change to parameter number N35.
    • Press Data Enter again to show the Setting Increment.
    • Using the Up or Down Arrow keys to change the Setting Increment to 1180.
    • Press Data Enter again to accept the Setting Increment.
    • Press the DSLP button on the VFD keypad to scroll through the illuminated modes until FREF (frequency reference) is selected.
    The VFD display will now read RPM/1000 i.e. 12,500 RPM will display as 12.5.
    Jun 2006
    Santa Rosa CA
    Just a quick clarification, the ShopBot DeskTop/HSD spindle package I use in production has a Delta S-series VFD. It also can be setup to show RPM but unlike the Yaskawa, the decimal point floats with RPM change making the actual RPM reading confusing.
    Ed
  1. Hz to RPM chart
    By Kyle Stapleton in forum ShopBot Desktop
    Last Post: 09-24-2015, 07:49 PM
  2. Free: Bits, Feeds and Speeds Chart
    By fmihm in forum Techniques for Cutting, Drilling, Machining
    Last Post: 10-06-2010, 10:24 AM
  3. V-Bit cutting width & depth chart
    By curtiss in forum Techniques for Cutting, Drilling, Machining
    Last Post: 02-08-2009, 08:22 AM
  4. Hsd frequency to rpm display change?
    By 3ps in forum Archives2008
    Last Post: 01-23-2008, 11:21 AM
  5. How to make your VFD display RPM and not frequency
    By ed_lang in forum Archives2007
    Last Post: 11-09-2007, 11:16 AM
