Results 1 to 9 of 9
Thread: Remote vacuum gauges?
    Oct 2000
    Atlanta GA
    Default Remote vacuum gauges?
    I'm just finishing up a replacement vacuum manifold (photos coming soon) and wanted to add a bank of vacuum gauges, one for each zone. I know, seems like overkill, but we've lost sheets of material because the operator forgot to open the rest of the zones when changing from a partial sheet back to full sheets. A quick glance at a bank of gauges should clue the operator in as to whether or not all the zones are open.
    Any reason why I cant use a fitting and some tubing to locate the gauges in a convenient place? It would only be 3 or 4 feet at most. I have some stiff 3/8" ID tubing - seems like a simple elbow into the bottom of the table and another fitting into the back of the gauge would be all it would take.
    Seems so simple I'm embarrassed to ask about it, but it's not something I've tried before, so before I rout 8 holes through my table - yes or no?
    David Buchsbaum
    Beacon Custom Woodwork, Inc.
    dba Atlanta Closet & Storage Solutions
    404-309-9146
    david@atlantacloset.com
    atlantacloset.com
    beaconcustomwoodwork.com
    There is no problem doing that, David. In fact, you can use automotive type gauges along with the capillary tubing that comes with it. Just make sure it is a mechanical gauge and not an 'electric' one that requires a remote sending unit. The price difference will tell you which is which right off the bat.
    Happy plumbing
    Dec 2008
    Diamond Lake, WA
    David,
    Before I redid my plenum I had 4 zones and a vacuum gauges for each zone. I ran a flexible piece of hose from each zone to a gauge. Worked great.
    With my rework on my plenum into 7 zones controlled by knife valves, I just have to remember which zones I need to open and close. Nobodies fault but mine if things get screwed up. So far, so good. The vacuum gauge on the current configuration is mounted close to the operator station and has a long plastic tube (about 8 feet) that goes into a hole in the pipe where it goes into the Gary Campbell vacuum box. Works great.
    Don
    www.dlwoodworks.com
    Jul 2005
    Brookline, New Hampshire
    David,
    If you have four spare input discretes, you might consider using these adjustable vacuum switches http://www.ebay.com/itm/Group-Of-4-Gems-Adjustable-Vacuum-Switches-No-Reserve-/251231022903?pt=LH_DefaultDomain_0&hash=item3a7e89 2f37 ($20 + $13 shipping for a set of 4)
    They could make sure the vacuum pressure is acceptable before the cutting would start.
    Paul Z
    garyc Guest
    David...
    Pic here, along with a little info.
    http://www.shopbotblog.com/index.php...-vacuum-setup/
    Jul 2011
    Atlanta, GA
    David,
    I used MSC Part #63148167 for my gauges. I had originally bought the Summit Racing automotive gauges and 3 out of the 6 I had ordered had incorrect readings. That's probably not always true but that was my experience. Here's some pics of my setup:
    Jun 2004
    Springfield Mo
    Default so cool
    Don't know how one could improve on Paul's setup...
    Better just send David B. out the cut file for a few bucks or even lots of bucks....
    Jul 2011
    Atlanta, GA
    Here's the .dwg file for you guys to use if you want.
    PRT Vacuum Switch Board.dwg
    Oct 2000
    Atlanta GA
    Thanks for all the responses. The new manifold is up and running great. I have the gauges and will get tubing and fittings this week.
    David Buchsbaum
    404-309-9146
    atlantacloset.com
  1. Shopbot Remote
    By CNYDWW in forum Variations & Modifications of ShopBots
    Last Post: 09-03-2012, 10:50 AM
  2. remote turn on of my vac's and dc.
    By knight_toolworks in forum ShopBotter Message Board
    Last Post: 03-17-2012, 11:28 PM
  3. Remote alert
    By jwelin in forum Archives2005
    Last Post: 04-28-2005, 01:04 AM
  4. Remote Pendant
    By todd@mitrewright.com in forum Archives2004
    Last Post: 06-25-2004, 12:37 AM
  5. Remote Vacuum Pumps
    By robinsoncr@naxs.net in forum Archives2003
    Last Post: 05-30-2003, 10:54 AM
