Setting up desktop and system is telling me I'm missing 'slabbus.sys'. Any help is appreciated. Thanks.
Sounds like you did not install the USB drivers when you installed the control software. Try installing the control software again with out having the Desktop plugged into the usb port.
Ron Moorehead
R&S Design
ShopBot PRS Aphla 48 by 96
Laserpro Explorer 30 watt
Universal Laser 50 watt
3D printer
I only plugged in usb cable once download was completed. Shopbot recommended I go to the website and download current version and try that. I did, but still getting same message.
Go into the device manager and see if there is a listing for shopbot under ports if there is uninstall and then do a search for new
This is what I found out about your missing file:
slabbus.sys file is a common Windows file which is responsible for loading and processing the settings of related application or Windows function. A faulty slabbus.sys file can lead to slabbus.sys errors and bring you one of the below error messages:
The 28f0b910_0.dll file is missing
28f0b910_0.dll file not found
The 28f0b910_0.dll cannot be opened.
This application has failed to start to run on Windows because 28f0b910_0.dll cannot be found.
The module 28f0b910_0.dll was loaded but the call to dllregisterserver failed with error code 0×80004005.
At this link:
http://www.fixpcdll.com/repair-dll-e...sys-error.html
Ron Moorehead
R&S Design
3D printer
Thanks to all who have offered suggestions. After further research I've discovered my laptop was underequipped to run the bot. Wife isn't real happy I repossesed her newly purchased laptop (I was using her old one) to resolve my problem. Probably the first of many issues to come.
how old is the laptop I can run my bot with a netbook
