I upgraded to 3.8 and now the speeds in my .sbp files are being ignored or overridden by the Yaskawa box. Also, the Spindle Control window is not updating with the .sbp or the Yaskawa box.
What am I missing?
What am I missing?
When you upgraded it may have changed the model VFD you are using or the HZ from 60 to 100 or 50. Check that as it did it on mine on one of the upgrades. Also on mine I had to go in and reset the start TR on start up
Thanks Jerry. Is that something I need to do during installation or can I change later? If later, I have no idea where to find any of those items to change them.
you can do it later type in tr and click on the RPM that should bring up your fill in sheet
Who knew that was a button?! Thanks Jerry! I selected the correct controller and changed the HTZ and HTZ multiplier to 60 and 100.
I had the same problem .....did a search and found this post. Thanks guys ! Charlie
