Ok, lots of people have posted a thread like this over the years. I didn't see the same issue I had so I'm asking for advice...
I was at the end of cutting a 1" thick piece of MDF (about 10' total cut length) done in 6 passes. The last pass was about 1/10" and it was on the last leg, about 12" to go and the bit broke. I touched the bit moments after it broke and it was cool to the touch. The chips looked good and it sounded like it was cutting normally before it broke. I'm ashamed to say that I finished the cut with (of all things) a hand saw.
I used the default settings for speed and RPM.
I've read that bits are broken in three's so I'm asking for advice before I break the other two. I am unfamiliar with MDF. Did I do something fundamentally wrong? Should I adjust RPM, speed or cutting depth when using MDF?
Thanks.
