Results 1 to 10 of 11
Thread: Black Edgebanding Help
Hybrid View
    Jul 2011
    Chicago
    Default Black Edgebanding Help
    I've got this cabinet job using black melamine that I have to apply this iron-on black edgebanding. I am having a hard time with it because after trimming I think the edges look horrible. I normally would hit the edges with some sandpaper to smooth it over but you can't do that with this black stuff. Does anyone have any suggestions or a process that has worked for you?
    John
    Jul 2012
    Tampa
    after trimming.
    iron the edge(corner) a little more "roundover"
    THEN: as you iron wipe the glue off.
    Banquet Tables Pro LLC.
    Dec 2011
    Piedmont, SD
    Use a very sharp carbide blade edge trimmer, or a very sharp chisel. If you must, rub back with a 320 paper to soften edge. Then, use a black wax fill stick. Run fill stick along edges and buff with cloth and / or white non abrasive scotch-brite pad. This will take care of any areas you may have chipped in handling.
    jeff
    We use a black sharpy to hid that kind of edge
    Jun 2012
    Philadelphia
    I trim my edge banding with a planer blade then "break" the sharp edge with a very fine file. bigest problem with the iron on stuff is the glue line. i prefer to use contact cement over hot melt when working with dark colors
    Jul 2011
    Timmins, Ontario, Canada
    Yup. I dont do any melemine work these days, but when I did, any black tape, or even HPL showed a lighter band under the face colour... just run a little permanent black marker over it and wipe the excess off with a little mineral spirits & rag.
    AJC
    Black PVC edgebanding is black clear through. Not like HPL which, unless you buy specific "through color" product, has a lighter color phenolic backing. If you have to use pre glued edgebanding, which is NOT a product defined for professional use in the shop, then you need to apply it correctly. A household iron made for clothes is not the right tool. You should be using a hot air heat source and something that applies a heck of a lot more pressure than than an iron to put it on. You'll get better results with a heat gun (not a hair dryer!!) and a tool that can exert more pressure on the tape, like a veneer blade.
    Jul 2011
    Chicago
    Dave.
    What material would you suggest to use for edgebanding this black melamine?
    John
    Jul 2011
    Chicago
    Default Thanks
    Hi Fellas
    Thanks for all the suggestions. Sorry for the late reply, flu bug has set me back a few days. Finally two days of sunshine in Chicago and ready to get back at it.
    FJ
  1. Wanted: Colorcore Black/white/black
    By WMNH in forum For Sale/Wanted - ShopBot-related items only
    Last Post: 11-02-2016, 08:37 AM
  2. Edgebanding station
    By harryball in forum Folder 2010
    Last Post: 08-11-2010, 08:44 PM
  3. Making Formica Edgebanding
    By erniek in forum ShopBotter Message Board
    Last Post: 08-15-2009, 11:50 AM
  4. BLACK MDF
    By woodworx in forum ShopBotter Message Board
    Last Post: 07-31-2009, 10:18 AM
  5. Edgebanding Guns & Machines
    By jeffreymcgrew in forum Archive2008
    Last Post: 12-18-2008, 04:29 PM
