Results 1 to 10 of 11
Thread: T-Slots
    Feb 2007
    Chicago Suburbs
    Default T-Slots
    Does anyone use extruded aluminum T-Slots as a material hold-down system for their Bot? We currently screw the materials down. That works great, but I am getting tired of replacing my table so frequently. Besides using a vaccum, I want to find an easy way to secure my large (4' x 8') and small (1' x 1') materials.
    Can anyone post a picture of thier current hold-down systems? Thank you.
    Paul Hardy
    Dec 2008
    Diamond Lake, WA
    Paul,
    I use a 4 x 4 piece of MDO with slots cut into it. In these slots I put T-track recessed 1/16" below the surface. I made some clamps that have the shape of half a biscuit and will fit in a biscuit slot. When I create my blanks for cutting/carving, I cut #20 biscuit slots and then use the combination of T-tracks, and the 'clamps' to hold material down. The vacuum system then holds the MDO nice and flat.
    Disregard the slots cut at 90 degrees to the T-tracks. I thought I would also put T-track there but decided against it. The next MDO board will only have the slots for the T-track.
    Picture attached.
    Don
    www.dlwoodworks.com
    Delray Beach, FL
    You may want to check out this article written by Dave Buchsbaum some years ago:
    http://www.shopbotblog.com/index.php...ew-friend-cam/
    Lots of guys have used his cam holders and track idea.
    Sep 2009
    Surrey, UK
    It's worth doing a forum search on the subject as well. It comes up a lot. I remember posting pictures of my setup at least three times.
    I outfitted my table with both traditional (wood) and T-slot extrusions. I have it split with a 96x48 section of wooden table with a vacuum plenum and 13.5" of clamp area using the T-Slot material. I use 4.5" x 1.5" (series 15) extruded aluminum from 80/20.
    The extrusions I use are slightly smaller than SB's standard side components (6" x 1.5" vs. 4.5" x 1.5") but the same T bolts fit.
    A standard 5/16" carriage bolt works great in the series 15 style extrusion.
    Here's a picture of my setup:
    Jan 2008
    Orange, CA
    Depending on your material, pin nails may be a good alternative to screws since they don't chew up the spoilboard and remove easily with pliers.
    Feb 2007
    Chicago Suburbs
    Default Slots
    Everyone, thank you all for your wisdom. Some people go to Google for answers, but I have found that the best answers are found on this forum. I will let you know what we decide.
    Sep 2008
    Quote Originally Posted by benchmench View Post
    http://raptornails.com/ these work great http://www.youtube.com/watch?feature...&v=8VzekKsbWdA
    Vector Studio 22
    Jul 2011
    Timmins, Ontario, Canada
    I use aluminum T track for 90% of my hold downs. I have the strips of 3/4" MDF holding down the track on the base layer of 3/4" MDF... glued and screwed from underneath.
    I use the Incra brand aluminum clamps - they can hold down up to 2 1/2" thick material. I have the track spaced so I can get on the outer edge of a 48" by 48" sheet.
    I still screw down custom fixtures, etc from time to time but most of the time 4 or 6 clamps does the trick.
    AJC
    Nov 2007
    Vankleek Hill, ON
    Andrew,
    Do you have any issues with the MDF strip edges chipping during the flattening routine?
  1. Key Hole slots
    Last Post: 05-05-2016, 10:04 PM
  2. Flatpack Slots and Tabs
    By zorlack in forum Archives2008
    Last Post: 10-09-2008, 11:09 AM
  3. Biscuit Slots
    By bakerkr in forum Archives2007
    Last Post: 04-19-2007, 10:33 AM
  4. How to cut slots in white oak without burs??????
    By woodesign@sonmedia.com in forum Archives2004
    Last Post: 01-27-2004, 09:20 PM
  5. Cutting .028 slots
    By srd1@bright.net in forum Archives thru 2002
    Last Post: 02-04-2001, 07:17 PM
