am using 3.6.44. this has happened twice now. looses x,y location. first time i just happened to notice that it did not go to the correct start location for a program (this is a program i have run several times with no problem). this time i had just finished aligning bot to a jig. i then did a k move (including control for high speed) to move bot out of way to put item in jig. then told bot to go back to the 0,0 -- and lo and behold is was some 3 inches off on x and about 1 on y - did not do a check to see how much it was off - it was just way obvious.
between the alignment and move to 0,0 all i did was a k move
is there a bug in the program or can someone give me an idea of what i am doing to cause this problem.
much thanks
don
