Thought I might share this with fellow Buddyites! Same basic idea as Andrew except have used 2 X 2 X 1/4 aluminium angle along both edges of the table and widened the table to get better support. Held on with 1/4 cupheads with car washers underneath to make alignment easier. If you used flat rollers this would never be an issue BUT you can get swarf under the rollers. Instead of castors I used ball bearing phenolic rollers (pinched from my wife's quilting machine spares). Table base is 1" moisture resistant MDF. Had to dado the tracks as I bought the wrong stuff. Didn't realise it came in 9mm and 12mm high. Used Andrew's track spacing - spot on thinking Andrew! Brackets made from 2 X 1/4 flat aluminium. You might be able to spot how close the surface was to flat when installed if you look closely at the surfacing. Used 18mm MR MDF for top surface screwed from above (no glue) and will be using Andrews method of a sacrificial spoil board (got a heap of 8X4X5mm ply for $5 a throw)
Have done 300 panels since install and really works well - thank you Andrew as I haven't got an original thought in my head! Thank you Russel for the removable slat idea. The pic of the job shows how bad things were before the mod even with a daily resurfacing. Tear your hair out territory and not a real happy customer either!!!!!!!!!
In my view the ultimate table mod for a Buddy would be to have another power stick (without stepper) along both outside edges. This would have to be perfection I reckon! Would love to hear the suggestion of others.
