Results 1 to 5 of 5
Thread: Spindle requirements
    Default Spindle requirements
    I am trying to wire up my shop with the thought of getting a 1 phase 2.2 HSD spindle and was wondering what size wire and breaker to get. The run form the panel is 50 feet.
    Mar 2009
    Eastern Delaware
    you will need a 30 amp 220 breaker if it is a HSD 2.2 horsepower spindle from Shopbot.
    #10 should do it even with a 50 foot run, but I would check with your local code authority to be sure. I think if it is type THHN wire in conduit you can use #12, but I wouldn't do it for the tiny cost savings.
    Jun 2007
    Sadieville, Kentucky
    I have the 2.2 single phase spindle and we wired exactly how Bob recommends. The nameplate on the VFD reads 230V / 17.5A.
    Dec 2008
    Diamond Lake, WA
    #10 is rated at 30amp so it works with no problem. Just make sure you have a good ground setup as I've found the PRS Alpha to be a little sensitive if your ground system is not good. Also, make sure you have a really good grounding system for the entire Shopbot all tied into the electrical ground. We used the grounding recommendations outlined, I think it was, in the Shopbot Wiki.
    Don
    www.diamondlakewoodworks.com
    May 2009
    , Saint Petersburg Florida
    I had to drive a seperit, 14ft. ground stake and used #6 copper straned to the Electrical box and to the control box to eliminate stay signals and noise.
    It's not fun when you have to track problems down.
  1. Power Requirements
    By dewey_dog in forum ShopBotter Message Board
    Last Post: 03-08-2016, 06:25 PM
  2. Computer Requirements
    By gary_k in forum ShopBotter Message Board
    Last Post: 11-30-2011, 11:29 AM
  3. Spindle Power Requirements Needed
    By kenz in forum ShopBotter Message Board
    Last Post: 11-10-2010, 09:03 PM
  4. Electrical Requirements for a 4HP spindle
    By zeke in forum Assembly & Maintenance
    Last Post: 04-09-2009, 05:16 AM
  5. System Requirements
    By smk in forum Archives2006
    Last Post: 10-21-2006, 11:49 AM
