Results 1 to 10 of 20
Thread: Sanding mop
    Jan 2013
    Massachusetts
    Default Sanding mop
    Can anyone say roughly how long a sanding mop lasts? I tried making my own, but they dont seem to lasy long. I'm trying to sand 3D relief with some intricate detail and sharp edges. Using 1/16" ball nose at roughly 1ips @ 10,000 rpm but getting very faint lines.
    Nov 2011
    Mission B.C.
    Angelo,
    Try reducing your stepover, when setting up your bit perameters.
    Rik
    Feb 2013
    New Berlin IL
    I think most are happy with a 10% step over. We use a 8% for .125 ballnose bit. And we set the roughing cut on a .25 down spiral end mill to .125 pass depth. Both of these adjustments extend the cutting time, but to us it is worth it.
    Sep 2009
    Jar-Din Woodworks, Keithville Louisiana
    Default Radial Bristle Disc
    Don't know how big your project is but have you ever used radial bristle disc? they will preserve your detail and they clean up really well....you can get them at
    foredom.com or google search to find dealers..Radial Bristle Disc..
    Raymond,
    How do you use that Radial Bristle Disc thing? What tool are you attaching it to? Looks interesting.
    Mar 2005
    Cabinets Plus of Augusta, Hephzibah Ga 30815
    I have mine attached to a dynabrade end grinder . 3m makes the ones i use
    Sep 2008
    Vector Studio 22
    say this 3 times fast.....
    Radial Bristle Disc
    Radial Bristle Disc
    Radial Bristle Disc
    they look like they might last longer then a sanding mop......
    Words of Wisdom:
    Jan 2013
    Massachusetts
    I used 10% step over for finish cut and 50% for rough cut. Can a radial bristle disk work well in a hand drill? My project is too big otherwise. Thanks
    Sep 2008
    drop the finish pass stepover to 6-8% takes longer to cut but should save lots of hand work
    Vector Studio 22
  1. Sanding Corian
    By curtiss in forum ShopBotter Message Board
    Last Post: 11-30-2014, 05:04 PM
  2. sanding issue's
    By POPS 64 in forum ShopBotter Message Board
    Last Post: 06-19-2014, 11:03 AM
  3. A Better Sanding Method
    Last Post: 06-14-2013, 08:42 PM
  4. sanding
    By twelchPTM in forum Techniques for Cutting, Drilling, Machining
    Last Post: 01-29-2013, 12:10 AM
  5. A sanding tip
    By GlenP in forum ShopBotter Message Board
    Last Post: 11-25-2012, 11:08 AM
