Results 1 to 7 of 7
Thread: Nudge?
    Jan 2013
    Massachusetts
    Default Nudge?
    When you stop a toolpath and nudge the z axis does that effect your z zero. Does it stat nudged when you part load the next file?
    Jun 2012
    Philadelphia
    Quote Originally Posted by angelosart View Post
    yes ne nudge comand esentially moves the z your desired amout from the current zero and re-zeros at that location
    "The most valuable tool I have is the experience of others" - Me
    Am I missing something How do you do a nudge I am using SB 3.8 software.
    'MN' or you can also do it when pausing a file and choosing to Move/Nudge.
    "It’s easier to fool everyone than it is to convince them they've been fooled" - Mark Twain
    Jan 2016
    Orlando, FL
    I have a similar question regarding z-axis nudge.
    I am doing a final profile cut, and I noticed that it wasn't quite cut all the way through to the spoilboard, say .002" not low enough. How would I use the nudge command to lower my tool in this instance? Do I nudge in the negative direction? Positive direction? I tried both, but it seems like either I didn't nudge it enough, as I was not getting the tool to cut all the way through my material. I ended up going back into vcarve, editing the toolpath, and reloading the .sbp
    Enlighten the neophite, oh wise ones!
    PRS Alpha 96" x 60"
    Dec 2011
    Piedmont, SD
    A negative value nudge should bring you closer to the spoilboard. If you watch closely, you can actually perceive this movement and verify it's going the right direction.
    As always, it's a good idea to find out why you need to adjust in the first place.
    - Surface the table recently?
    - Major atmospheric shifts in humidity?
    I've learned to surface mine a bit more regularly, and enjoy much more accurate results. Clean cuts, very little witness lines on the table.
    jeff
    cnc routing, portland or
    If you don't cur cut all the way through I usually just stop the machine lower the bit it and cut that last path again. like if the pockets are not coming out deep enough you usually need to lower the bit then do it all again. but I use nudge too sometimes just depends. But bit sharpness can change the depth of cut like a downcut will start leaving a little bit on the bottom of the cut as it dulls.
  1. Does nudge last on a second rep?
    By scottp55 in forum ShopBotter Message Board
    Last Post: 03-12-2016, 07:09 AM
  2. Nudge Button Gone In 3.8.26
    By PNast in forum Troubleshooting
    Last Post: 10-28-2014, 09:54 PM
  3. nudge
    By jerry_stanek in forum Troubleshooting
    Last Post: 12-24-2013, 10:36 PM
