Thread: C0-9 and C# custom command definitions
    Jun 2013
    Tuscon AZ
    Question C0-9 and C# custom command definitions
    Hi All,
    My version of the shopbot software (V3.8.4 PRT) that i'm using with my BT48 PRS Alpha has under the Cuts menu listings for C1, C2, C3, C5, C6, C7 and C9.
    1-3 and 5-7 have titles that explain what they do. The C9 comment is blank.
    In addition C# 88-91 Have no explanation and
    C# 99 says [JH] JOG HOME (see notes in file regarding this example
    What file??? Where are these commands defined/explained.
    Someone suggested ...ShopBot/Developer Tools/Docs But the only file in there is a .txt file SbW_CommandLine_Format.txt that explains how to run files from the command line
    Sep 2009
    Surrey, UK
    They are in the "c:\sbparts\custom" folder.
    If you click on Programming and Developer Resources on the SB3 Help menu it will open the folder with the developer resources (one level up from where you were looking). The ProgHand PDF file is probably of the most interest to you.
  1. Custom cut file
    By Keith Larrett in forum ShopBotter Message Board
    Last Post: 12-20-2016, 03:56 PM
  2. custom files
    By jerry_stanek in forum Variations & Modifications of ShopBots
    Last Post: 04-05-2012, 04:17 PM
  3. Custom listing
    By kevin in forum ShopBot Businesses
    Last Post: 11-08-2011, 05:59 PM
  4. Custom 3D Sign
    By NeathawkSigns in forum Folder 2011
    Last Post: 10-27-2011, 06:59 PM
  5. Custom Z-Zero Plate Help
    By RickWyatt in forum ShopBotter Message Board
    Last Post: 10-19-2010, 07:39 AM
