I 'm in need of some suggestions on tool-pathing a texture at the bottom of a pocket. The texture needs to blend into the radius at the botttom of the pocket without the tool touching the edges of the pocket and spoiling the textured effect.
I first started these doors on a much smaller CNC Shark and was forced to fab the doors from numerous pieces. Since I was doing the door panels one at a time, this problem never came up.
The plan with the Bot is to do all of the machining after the full-sized door blank is glued up. I've got eleven more of these to complete. The photos show the textured effect I'm trying to acheive. I need the texture to appear to fade into the edges of the pocket. I'm using Aspire to generate the tool paths. Thanks in advance for any suggestions.
Rick Reese
Shelton, WA
