Hi, I was on the phone last night to shopbot tech support as I'm having issues with the latest software version of SB3.
I have found an issue where it wasn't performing the C3 command correctly. This was due to the setting file not changing from the default of 0 (inches) to 1 (metric). Once I changed that value manually and saved the file I have now come across another issue.
When doing the C3, it will complete the Y axis correctly but it fails on the X axis once it hits a value of -250.01. Obviously this is a limit issue but I'm unsure what value to change.
Can anyone shed some light on what value I need to change to let it move further than the -250 value. I assume that it is some sort of imperial to metric issue where normally an imperial value of 250 is more than enough safeguard but 250mm is a relatively shorter distance hence the failing.
Regards,
Shane.
