For the few projects I have done, one of the things I am bumbing into, is that the tools in the default databases share some of the same tool numbers. I know this is easy to change and have had to go back in and change numbers and proceed on.
this brings up several different questions. If the all of the toolpaths are sent to the machine seperatly, then it would make no difference. Do most you combine the tool paths into one file, or send seperate files for each different tool? For the tool database I see tool numbers are available into the thousands. Do you set up a numbering system, certain number ranges for differnt kinds of tools? Numbers set up for the same tool with different peramiters?
I have been combining my tool paths into one file, when running the program stops and prompts me to change tools to tool number "X". I end up taking some cheat notes at the design computer to remember the number for each tool. works OK for my simple things now, but it seems like setting up some kind of standardization now would be helpful later.
How do you all set this up? Thanks....
