Hello,
Here is the July 2013 project I created for owners of Aspire 4 (and future higher versions). It is a FREE download, courtesy of Vectric!
http://www.vectric.com/cool-stuff/pr...her-clock.html
This FREE project features a miniature version of a classic Grandfather Clock “shrunk” down to a height of about 42" ! The clock is constructed in sections/layers with the Vectric Aspire files (17 of them) ordered and organized to correspond with the chronological build process outlined in the included illustrated PDF instructions.
The project goes together quite easily. Perhaps the greatest challenge is the cutting of a couple miter joints on one of the base layers and the topmost clock head bonnet, but even this task is a straight-forward process for the average woodworker.
Special thanks to ShopBot and Vectric for making this project possible!
• I created the design/layout using Vectric's Aspire 4 software. (You must own Aspire 4 or later, to be able to run this project.)
• I used a ShopBot PRSAlpha BT48 to run this project and the toolpath settings were specifically for that machine and bits I used. You can make changes to suit your particular machine, bits, etc.
The project uses the following bits...
0.25" down-spiral End Mill
0.125" Ball Nose
0.5" Ball Nose
90-degree V-Bit
Apply your choice of finish. I am applying an oil paint glaze/stain on my prototype using artist's oil paints (a technique I learned from my aunt many years ago in one of her Tole painting classes).
