Results 1 to 5 of 5
Thread: ramping between pockets possible in 2D?
    Dec 2012
    Houston, TX
    Default ramping between pockets possible in 2D?
    Not sure if ramping is the correct term....I need a gradual incline/decline or ramp between two areas that are pocketed. These pocketed areas are right next to each other. Is this possible with VCarve Pro?
    Have you tried using the Fluting toolpath?
    Dec 2012
    Houston, TX
    Thank you for the Fluting suggestion..it seems to be working. I am ramping a skinny oval shape..so what I am having to do is draw lines inside the oval for the fluting toolpaths. Is there an easier way to acheive this without having to draw so many lines?
    Sep 2008
    what's so hard about drawing the lines? make 1 vector> use array tool to create the amount needed
    Vector Studio 22
    Dec 2012
    Houston, TX
    Sure, I see your point about using the array function to copy the lines, but I must be missing something. If you are filling an oval shape with an array of copied lines, won't you have a lot of trimming to do on the lines that overhang the oval form? i.e. not all the lines will be the sam length in an oval.
  1. How can I get cleaner pockets?
    By awalt1250 in forum ShopBotter Message Board
    Last Post: 01-26-2014, 10:18 AM
  2. Need help with texturing pockets
    By Rick Reese in forum Techniques for Cutting, Drilling, Machining
    Last Post: 07-26-2013, 09:52 AM
  3. Same distance pockets
    By Guerra Cues in forum Aspire
    Last Post: 11-25-2011, 11:56 PM
  4. Pockets
    By oddcoach in forum PartWorks
    Last Post: 10-09-2010, 05:19 PM
  5. Multiple pockets
    By coach in forum Techniques for Cutting, Drilling, Machining
    Last Post: 07-02-2009, 08:33 PM
