Results 1 to 10 of 12
Thread: Lord's Supper
Hybrid View
    Jan 2009
    Texarkana, Texas
    Default Lord's Supper
    This piece actually began while shopping at IKEA. I really like that store. In the kitchen cabinet area of on the second floor, noticed some fir shelf material. The shelves are 1/2" thick glued up stock. They are only $5.00 ea. Glued up two slabs as when carving something that thin tends to warp. This file is an STL and imported into Aspire 4. Roughing pass with a .25 endmill. Finishing pass was with a .125 ballnose with a 10% step over. After the milling, followed up with 120 grit flap sander on a battery powered drill. It only took a light pass in the areas of end grain. Total sanding time was maybe 10 minutes. Primed with acrylic white trim paint, then brushed on 2 coats of Modern Masters Metal Effects Bronze. Immediately after the second coat as it was still wet, sprayed a blue acid patina. Next morning, buffed with a green Scotch-brite pad to remove the extra patina dust and polished the areas that did not get covered with the sprayed acid. The combination of the patina and bronze sure gives the appearance of metal. A couple of co-workers asked where I bought the bronze casting? Guess the look is effective.
    Jan 2012
    Moose Jaw, Saskatchewan
    Looks really good, is that the file from vectorart.com?
    Terry,
    I like that effect. I recall Bill was demo'ing some sculpt Nouveau and had this piece that looked like aged copper and i picked it up and it was foam! That was a weird sensation because i expected it to be a heavy object. Very cool
    Words of Wisdom:
    Jan 2009
    Texarkana, Texas
    Mike,
    You are correct. This is the link to the file.
    http://www.vectorart3d.com/store/ind...etail&ID=50553
    I did find a different file from Hungary.
    http://hobbycncart.com/load/rendelheto_for_sale/7
    You will need to right click on the page to translate into english.
    I have not cut it as of yet. It looks like a more detailed file. This company uses PayPal to place your donation for the file.
    Jack,
    Bill is who turned me on to this type of finishing. Also completed a EPS foam carving and used the Modern Master's metal effects copper. You are correct, I like watching people first touch the piece. Then their eyes open big when they pick it up and about throw it across the room.
    Jan 2012
    Terry
    Thanks for the info, just put in a donation for the file.
    Will try and get to it in the next couple of weeks and let you know.
    Mike
    Jan 2009
    Texarkana, Texas
    Mike,
    I like this file better as it has more detail. The price was right as well. Set it up in Aspire easily. Set it up on 2" stock approx 24x48. Now this is just the CAD work as I not cut it yet. In the software, I made the model 1.75" tall. Just ran a finishing .125 ballnose and cutout .25 endmill tool paths only. No rough cut as I was impatient to see what it would look like on the screen. The computer states 14 hours and 21 mins. total time without roughing. Saved the picture and it looks great on the screen.
  1. Praise the Lord and Hallilujah, She's Moved!
    By harryball in forum ShopBotter Message Board
    Last Post: 01-14-2015, 09:27 AM
  2. The lord’s prayer in Romanian.
    By knight_toolworks in forum Folder 2008
    Last Post: 06-29-2008, 01:07 AM
  3. THE LAST SUPPER
    By jimmya in forum Folder 2008
    Last Post: 04-29-2008, 04:26 PM
  4. Last Supper
    By jamesb in forum Product/Supplier List and Requests
    Last Post: 04-18-2008, 10:41 AM
  5. Last Supper .rlf
    By gus in forum Archives2006
    Last Post: 12-06-2006, 02:19 PM
