Results 1 to 5 of 5
Thread: Port #4 Problems
    Oct 2007
    William's Architectural Workshop, Henderson Texas
    Default Port #4 Problems
    Just relocated my shopbot PRS Standard and hooked it up just as before. I attempted to home the X & Y axis, using the proximity switches, however, port #4 displays a red outer circle with green in the middle and port #3 has a green outer circle with yellow in the middle. It is not blinking and the X & Y axis have not gone past the limit switches. Not sure if the picture will come through or not. I need step by step instructions if available. Thanks...William Moore
    Looks right...It appears that the tool is sitting on the X prox by its solid yellow color on Input#2.
    Oct 2007
    Thumbs down
    So #3 & 4 are correct and #2 should be, what color? The tool is not sitting on X prox but light is on, so could it be a bad switch?
    4 is lit up blue any time the tool is in motion OR when the keypad is open.
    #2 is X axis Prox
    #3 is Y axis Prox
    If X/#2 shows it is active, the sensor either senses metal, the wiring is incorrect, broken or the switch itself is bad.
    Oct 2007
    Thank you Brady, I suspect the switch is bad. I appreciate the information...William
  1. What is this Port for?
    By Walt_S in forum ShopBot Desktop
    Last Post: 01-17-2017, 01:12 PM
  2. Port Issue
    By gsmith in forum Troubleshooting
    Last Post: 11-02-2012, 07:37 PM
  3. Serial Port
    By donchandler in forum Troubleshooting
    Last Post: 12-30-2011, 11:46 PM
  4. LOSING COM PORT
    By frank134 in forum ShopBotter Message Board
    Last Post: 02-21-2010, 11:53 PM
  5. Port changes on me
    By eklug in forum Archives2007
    Last Post: 09-10-2007, 10:07 AM
