Results 1 to 4 of 4
Thread: More fun with foam
    May 2011
    ny
    Default More fun with foam
    Took the gears and my gearhead design and stuck them on the shop they are in place with rare earth magnets, the gerahead came from my clock file I made when I finished the garage.
    That seems awful dangerous to hang something that heavy right above your head as you walk in the door!
    Words of Wisdom:
    Brian, I agree with Jack on the placement above the door. In addition supporting such massive weight mid-span on rib-panel between your horizontal stretcher and purlin fascia is bound to cause panel failure. Scott
    Jul 2010
    Wyoming, Illinois.
    Yes,
    The foam might fall and as it floats down you could look up and walk into the door, causing a heck of a bump. Be careful!
  1. HDU Foam
    By jwa1156 in forum ShopBot Desktop
    Last Post: 09-17-2014, 06:22 PM
  2. Foam
    By twelchPTM in forum ShopBotter Message Board
    Last Post: 07-26-2012, 04:51 PM
  3. first foam
    By magic in forum Sign Making
    Last Post: 01-27-2011, 06:24 PM
  4. Need HELP with Foam job
    By donald_smull in forum ShopBotter Message Board
    Last Post: 03-20-2009, 03:39 PM
  5. Cutting foam & tearing foam
    By dubliner in forum VCarvePro and PhotoVCarve
    Last Post: 11-11-2007, 05:13 PM
