X-axis slow down while cutting file??
I was cutting a 3D file last night where I am rastering in the X direction. The piece is 3" wide x 64" long, so the X movement is along the 64" length. I watched the cut the first 5 minutes and everything was going fine. My move speed was set for 3 IPS. The file should have taken about 1-1/2 hours to cut. After about an hour I checked on the progress and I was only at about 40% completion. I started watching and the X movement would slow way down to maybe .5 IPS in places. This would happen in places where no Z movement was required. At the edge of my final cutting, the machine was making full 64" length passes where no Z movement was required. That whole distance it would move at the very slow speed. I then manuaully raised up the move speed with the keyboard. It didn't do anything at 3.1 IPS, then when I clicked again at 3.2, it took off full speed. I could back it back down manually to 3.0 and it still ran fine. Then when it got to the end and began to change direction, it would slow down again, until I manually adjusted the move speed.
I have never seen this before. The Aspire file looked fine when I checked the code. I am running the pre 3.8 control software. Any ideas what this would be?
After the file finished, I did some manual MX commands at 3.0 IPS and it was fine.
PRT Alpha with 7.2 upgrade, indexer, and PC router
